Hi pixelhouse, do you get that same error anytime you try to save like if you start up a fresh instance of MoI and create a sphere and then save it does that work ok?
Or does it only happen with that particular file? It looks like you've got a massively complex single surface there, maybe that's causing a problem. You could try generating a less dense surface to see if that would help.
