History Enabled Curve Arrays
7478.2 In reply to 7478.1
Hi Alex, currently it's not possible to turn on history for arrays - that's because the history mechanism attaches records on to each object that is generated and when the array tools created a large number of objects the history data ended up causing significant file size bloat. So for now to avoid that from happening all the array tools have history records suppressed for them.
You can get the result you want though by using the Transform > Rotate command to set up your copies rather than using Array. Use the "Make copies" option in Rotate, and the results from that should then work to have history updating turned on for them.
In the future I want to change how history works and instead of attaching records on to each generated object I want to instead keep a log of the sequence of actions that happened. When that happens it will then be more feasible to enable history for arrays.
