> Rebuild is necessary or not ?
Only if removing segmentation in the curve is needed. So for doing a loft for example you want the loft to be in one piece and so you need to rebuild it so the curves are made up of one segment instead of multiple sub segments.
2-rail Sweep operates a bit differently with segmented rails and automatically merges tangent rail segments together into longer rail segments.
