if you want to remove that crease without varying the curve too much, you can first join the curves, then add 3 control points on each segment at position very very close to the join point. Then delete the join point. Assuming it's a nurbs curve of no higher than degree 3, the effect will not extend past that 3rd new point...
jonah
