Viewport Hangs...
7436.5 In reply to 7436.1
Hi Rich, typically stuff like that is an indication of video driver problems. If you continue to see this problem you may want to try updating your video driver to the latest version and see if that helps any. Also another thing you can try is to set an option to disable multi-threading in the display engine, sometimes that causes problems with some drivers. There's a description on how to set the option for that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7385.3
