| Version BraidedBands4 should have all 6 Build types correct.The different Build types required some variations of the code.
 The unwrapCyl and unwrapDisk results are the same as each other, just rotated 90 degrees.  (Produces pLeads number of woven curves.)
 The two Linear versions are the same as each other, just rotated 90 degrees.  (Each version only produces one long wavy curve.)
 More than one Ply could be done by re-running script with different, appropriate, Midline Radius.
 Sweep can be done manually.
 A chaining script could be done?
 A node version?
