| The racetrack has to be a closed curve, for the points to Array Curve properly,because for an open curve, the only points that ArrayCurve on the curve are Start and End points.
 I Flowed a sine wave onto a circle, but did not quite get it closed.  (It looked closed from a distance)
 Array Curve of points at miscellaneous points on the curve gave weird (but correct) results.
