| I did a bit of an experiment and for me loft seems to produce a smoother outcome.  Both look fine in Moi but the loft export seems to be better.
The subdivided car always seems to have some artifacts even when I put the poly count to the limit and try smoothing in Carrara.
Whereas while the lofted car is not perfect its noticeably smoother.  I think it might be something to do with surface normals?
I have learned a lot from your tutorial and the help you have given.  If I ever manage to make this car Ill post it to this thread if that's OK.
I attach the pre-subd version of the one in the picture at the top of this post. |
