| Car Tutorial Part 20 - Badges
Ed Ferguson, CascadiaDesignStudio.com
Badges:
Finally, we'll add a couple of badges.  (Some cars don’t need no stinking badges, but ours does :)
The size is not important at this step as we will resize as needed when placing the badges on the car.
Draw a large circle and a smaller one that intersects.  Use Array > Circular to create three evenly placed around the large circle.  Select all four circles and Boolean > Merge.  The result is the curve in yellow.
Draw a profile curve and Revolve it into a round button-shape badge.
Position the curve made above over the revolved badge and Boolean > Merge.  Delete the unwanted piece and Fillet the remaining solid.
Make a copy for the front of the car and one for the rear.  Resize / flatten as needed and rotate as needed to place the badges tangent to the curvature of the car’s body.  Position so the badge slightly intersects the body.
I hope you have found this tutorial useful and will be inspired to make and share your own creations. |
