Hi delic,
> I thought that the networks, if done properly, would work.
The main way to use Network to make a large smooth surface is to do it all in one single big network rather than making numerous separate individual pieces. Every time you make a separate piece the end conditions of that piece will not have any special relationship to the other adjacent patch and so will usually have a crease between them.
You'll even want to mirror your curves and do the entire width of the object all as one network rather than doing half and mirroring it.
It's kind of a fundamental thing that curve or surface interpolation done in separate segments rather than all in one go will have creases in it, there is some visual explanation of that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.18
http://moi3d.com/forum/index.php?webtag=MOI&msg=1398.19
