How to set PDF page size and orientation
7369.2 In reply to 7369.1
Hi Terry sorry currently there is no way set up for adjusting the PDF export's page size or orientation. The PDF export is a pretty new feature and the focus initially has been just on getting the vector results. You will need to open the PDF in some other 2D drawing application to change those page properties right now.
I do want to make it possible to change those for MoI's output, hopefully that will happen for MoI v4.
It is possible to edit the page size in a text editor, this previous post describes how to do that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6522.4
If you don't have any 2D drawing editor for editing the PDF you could also use the command-line program mentioned here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6522.5
