Fuselage help please
7366.6
If you reduce the amount of fuselage cross sections used you can get a reasonable result with network-normal or lighter.
The trick with network is to use as few cross section curves as you can to define the shape and let the perimeter curves do most of the work.
You will need to experiment with amount of curves and their placement to get something that is good enough for your purposes.
EDITED: 25 Apr 2015 by KEVJON
Size: 54.9 KB, Downloaded: 60 times, Dimensions: 800x454px
