inverse boolean wanted
7359.1
I have a lathed curve and a flat closed path which should cut parts away from the lathed object. but the inverse of what should be cut away is taken. I was able to solve it by using the trim command, but I wonder if this can be done with the booleans?
tnx
wim
Size: 45.9 KB, Downloaded: 38 times, Dimensions: 489x426px
