object axis?
7352.4 In reply to 7352.3
Hi Stan, yes the problem you're running into in this case is that MoI does not currently support instances, that's the difference.
In the future I do want to implement instances in MoI and then also make STEP import read those instances, and also make exports use instances when possible as well. That's a kind of long chain of work involved in implementing all those pieces so I'm not sure when that full sequence of stuff will be done. Then on top of that only a few file format export types support instances in them, for example there is no mechanism in OBJ format for doing instances so it would only be for a couple of formats maybe just FBX, I'm not quite sure.
I am in the process of investigating doing a 64-bit version so hopefully that will happen for the next version.
