Little help.....
7256.2 In reply to 7256.1
Hi joe, do you mean you're doing 3D printing with this?
You've got 3 separate solids in that file - the slab and the 2 cylinder pieces are all separate parts. Are you exporting each part to an individual file and printing them separately or are you trying to export that entire 3 solid set to just one single STL file?
STL files are generally meant to only contain one single solid in them, so it's probably going to confuse your 3D print prep software to receive a file with multiple solids in it especially with the parts pushing halfway through each other.
You probably need to either export each part into individual files if you want them to come out as individual separate printed parts, or if you want it to all be one single object then you need to select them and run Construct > Boolean > Union before you export it, so that they are combined into a single solid rather than multiple solids that collide into each other.
Hope this helps!
