flow command issue
7248.2 In reply to 7248.1
Hi forty,
the shown surface seems not undevelopable?? Flow makes the the distortion of the curves by itselve. So you should try to use a rectangle face as base surface to map the lines to your revolution.
It helps to switch on the control Points of both surfaces to have a look to the parameterisation. Or You can try to rebuild the surface by sweep -> two profiles -> two rails and try again.
Kind regards
Karsten
