hello everyone,
i have an issue with the flow command. i am trying to project a surface onto a irregular tube. therefore i have unwrapped all my surface and constructed a plane that is consisted of the true length of of a number of sections, so that i can project different patterns onto the surface without distortions (screenshot 01). but moi seems to project from an imaginary rectangle and not from the corresponding lines (screenshot 00) you can even see that the outline of the unwrapped surface is not even hitting the middle line on its broadest part.
is there a possibility to solve that problem and tell moi to use the real outline of my unwrapped surface instead of an imaginary rectangle or is there a workaround for a problem like this (using the projection mode is no option as i have to project irregular patterns as well and don t want to have a crease on top of the tube and of course there would be distortion if i used projection)
thanks for any help or suggestion,
forty
