Offset problems on voronoi pattern with MOI3D v3
load for example Torolf's image into MoI, which Pierre has posted, and redraw some cells with polylines. Then use your method were you showed to click on point 1 and 2. You will see that the closed line will not match. Now do the same with clicking in each corner of a cell and you will have the same closed line(s) as Torolf shows. :-)
BTW. i overlaid your right example with the left example in Photoshop and there is also a difference... :-)
Best regards
EDITED: 4 Feb 2015 by STEFAN
Size: 80.3 KB, Downloaded: 32 times, Dimensions: 520x216px
