cutter asst
721.4 In reply to 721.3
Hi Pat, this way will be a lot better, you won't fill up your attachment space nearly as quickly.
Just one more thing - when you create an image to attach if you can create it using the JPEG image format (the file ends in .jpg), that is a much more efficient format space-wise than BMP which you've got here.
So for instance each of these images saved as a BMP file here are 2 Megabytes, while the same image saved as a JPEG is around 90 Kilobytes, which is less than 1/20th the size.
So if you use JPEGs, you will be able to attach 20 times as many images before filling up your alloted attachment space...
