AMONIT modelling
7172.28 In reply to 7172.25
Hi Lara,
> I tried it with BoundingBoxCenter (before: bounding box center).
> No error this time - fine. But also not an operation - ces“t dommage.
It may be a little bit difficult to see the result - the command BoundingBoxCenter puts a point object at the center of the bounding box around the selected objects. So after you run it, a point object should appear, it will be a small marker at the center of the selected objects.
It sounds like you may be expecting something else to happen instead?
