Offset Shell question
7167.3
Hello,
Blend can be your friend in this case. I used G1 for the profile curves and swept the sides of the model and then just did a set of G2 surface blends to create the inner and outer corners. the remainder of the operations were the Planar command followed by Join to a watertight solid. I can put a short vid up if it helps.
EDITED: 8 Aug 2024 by OSTEXO
