OSX Redraw issues
7160.8 In reply to 7160.7
> changed the meshing angle from 10 to 13 problem solved, any clue :-/
My best guess is that's just a coincidence. You may see the artifacts again when your machine is heated up from some more continuous use later on.
If you run into it again you might try some machine cooling methods, that previous link has some ideas.
