Selection question
7155.4 In reply to 7155.3
Several ways. If you want to do it without using the scene browser, window select from right to left over the items, then select on the longer line to deselect it.
If the little underline is smaller enough than the longer one, a regular window selection will only select what is completly in the window, so start from one side and stop the window short of the long line, and the little one under should highhlight.
