Hi Gunter.
Do all of your other shortcut keys work properly?  I would try to disable a different one, say SineWave, by misspelling it in
the Commands folder say as SSSineWave, and seeing if it disables.  This would indicate the wrong Commands folder???
Note that the UnwrapCurve names all have to be spelled the same, without leading or trailing spaces.
In the Commands folder:
UnwrapCurve.js
UnwrapCurve.htm  (not .html)
Under Shortcuts:
Key: (for example U),       Command:         UnwrapCurve
Edit: I still think it is whitespace :-)
