Running MoI from Dropbox
7073.1
I've spent a bit of time trying to perfect the best way to run MoI IN SYNC (settings, moi.ini, commands, UI, etc..) on two computers-- the one at home and the one at work.
After a bunch of jumping through hoops and editing the WINE config files, I've rethought the problem and as usual I was just making things too difficult.
I'm on a Mac. The best plan is to just run MoI3D from Dropbox directly.
1. Copy the MoI v3.app over to a folder on my Dropbox.
2. In Finder, hold down the Option key and click on Go menu and select Library. This will take you to the hidden Library folder.
3. From Library, go to Application Support / Moi folder and select both moi.ini and moi_v3_license.key and COPY (Command-C).
4. Right-click on MoI v3.app(in Dropbox) and choose Show Package Contents.
5. Navigate to drive_c / moi folder and Option-Command-V (move both files). Now moi.ini and moi_v3_license.key are in same directory as the MoI v3.app
Voilá, the app should be able to be launched from both computers as long as they are using the same Dropbox account. Keep in mind, ONLY ONE LICENSE PER USER! Do not use this technique to share copies of MoI as not only is that illegal, but it also hurts the company as well as us paying users!
(Michael, feel free to delete this if you think it is inappropriate).
EDITED: 24 Nov 2014 by CHIPPWALTERS
