How to Blend this simple shape?
7065.3 In reply to 7065.1
Also another thing that can be a bit tricky with blends is if you have a separate cutting curve object sitting right on top of the surface edge. In a case like that with both the curve and the edge stacked on top of each other the curve will get precedence if you click on it and to make the blend you need the edge selected instead.If you run into that you need to hide or delete the curve so that you can target the edge that's directly underneath it better.
