[Scripting] Zoom to Center
7061.1
Let's say you want to zoom to the center of the viewport as opposed to the current method that zooms to the mouse cursor. This can be achieved by binding a couple keys to scripts in MoI and using AutoHotkey.
In MoI, create the following keyboard shortcuts:
PageDown=script: var scale = 0.20; var vp = moi.ui.getActiveViewport(); if (vp != null) vp.Zoom(1 + scale);
PageUp=script: var scale = 0.20; var vp = moi.ui.getActiveViewport(); if (vp != null) vp.Zoom(1 - scale);
Create the following AutoHotkey script:
#IfWinActive, ahk_class MoiMainWindow
; Zoom to Center
^MButton::
CoordMode, Mouse, Screen
threshold := 20
MouseGetPos, co_x, co_y
while GetKeyState("MButton", "P")
    MouseGetPos, mouse_x, mouse_y
    abs_offset := Abs(co_y - mouse_y)
    offset_sign := (co_y - mouse_y < 0) ? -1 : 1
    ; Zoom events only occur when the magnitude of the offset is at least as
    ; large as the threshold distance.
    if (abs_offset>= threshold)
        ; Determine how many threshold distances fit within the offset.
        multiple := abs_offset // threshold
        ; Mouse moved down.
        if (offset_sign = -1)
            Send {PgUp %multiple%} ; Zoom in.
        ; Mouse moved up.
        else
            Send {PgDn %multiple%} ; Zoom out.
        ; Update the stored y-coordinate.
        co_y := mouse_y
    Sleep 10
return
After executing the AutoHotkey script, you may now zoom to the center of the viewport using Ctrl+MMB. You can change the MoI "scale" and AutoHotkey "threshold" variables to adjust the sensitivity and smoothness of zooming.
EDITED: 23 Nov 2014 by BFEDACK
