rotating an object in 3d space
7053.5 In reply to 7053.4
Hi wim, I'm glad you got it sorted now! And yeah I should have remembered the orient tool for that case myself - yes if you want to rotate a surface by realigning its surface normal to a different spot the orient tool is probably the easiest way.
