blend & planar sections
7036.1
Hello,
I'd like to blend two aerodynamic shapes using blend + planar sections. I did the same (see picture) with similar shapes in the past and it worked fine but this particular version doesn't work for some reason. I assume it's related to the fact that the edge at the lower cut is broken into 3 lines at the very end.
How can I fix the problem?
S.
Size: 62.3 KB, Downloaded: 43 times, Dimensions: 585x300px
