no solid is generated
7016.1
Hi all,
I have a simple curve, made out of arcs and straight lines, and sweep it around a rectangle with rounded corners. I then select the open edges, click 'planar' and join the 2 planes to the sweep. I should get a solid, but instead get a joined srf. which makes it difficult to boolean of course.
If I try this with a simpler curve, like a 180 degree arc, then I get a solid.
What does it take to get a solid with the desired curve?
tnx
wim
Size: 17.6 KB, Downloaded: 24 times, Dimensions: 162x486px
Size: 27.2 KB, Downloaded: 30 times, Dimensions: 195x497px
