Snapping question (moving stuff around)
7005.2 In reply to 7005.1
Hi Spiney, if you move an object by directly dragging on it, it will position it from the point you grabbed on the object, not from the grid like you want.
But there is a different way of moving objects that will work for you - use the Transform > Move command (first command on the Transform palette on the side pane) rather than direct object dragging.
Transform > Move will let you pick 2 points to specify the movements, a base point and a target point. These points can go anywhere, the base point is not restricted to have to go directly on the object like how object dragging works.
So select your object, run Transform > Move, then pick the base point on the grid, and the target point also on the grid and that will do just grid based movement.
Direct object dragging is a sort of shortcut way of moving things but it's more focused on snapping objects together by matching endpoints to endpoints and stuff like that.
It's also possible to set up arrow keys to move things in fixed increments as well, for some info on setting that up see here:
http://kyticka.webzdarma.cz/3d/moi/#Nudge
