Thoughts about Flow
6991.6 In reply to 6991.5
Hi Heiner, if you're having what looks like randomness in the result it's most likely the result of clicking in slightly different areas on each surface on each run-through. For example make sure not to click right exactly on a corner of the surface, because what is actually targeted is an edge and if you click right on a corner it's pretty ambiguous which particular surface edge actually gets targeted.
Can you please post the 3DM model file that is giving you the random-like flow behavior? I will take a look at it and then maybe be able to give you some more specific advice on where to click on it to control it better.
I have thought some about trying to rework the Flow command to be easier to understand. It's somewhat difficult because it can be used in a lot of different ways.
