Loft - history profiles
6953.4 In reply to 6953.1
Hi Coolphone,
> And what if I want to add another profile to manipulate this surce? I'm copying one of
> the profiles by holding Ctrl, and when I move new profile surface doesn't change... Is it
> possible or I need to create new loft surface?
Yes in a case like that you'll need to delete your current Loft surface and make a new one using your new profile curve.
There isn't currently any way to update the history records stored with the surface to include the new profile without remaking it.
> How to Add Point on the surface?
It's a new feature in v3 that you can select a surface and add control points to it using Edit > Add pt.
But that will be for control point editing, what you see when you select the surface and run Edit > Show pts - that's a somewhat different type of editing than history update editing like you were originally asking about.
