Hi WN,
> Thank you, everything works, the other tabs are closed but I think I'll figure it out, or
> as you say it will take a couple of seconds.
Hmmm, yes it looks like when the startup scripts are run the main window has not yet been sized and that then runs into some trouble with the mechanism that compacts side pane palettes when the window is sized smaller.
I'll see about running the startup scripts slightly later than they currently are so the original script can work ok.
