Hi agonyii,
> If Moi sees any of its own files there then these files would get loaded first - instead of ones
> from the apps folder. In that case way we would be able to keep the original files intact and
> still able to keep all the addons we use.
I have some ideas along these lines for theme packages where a theme could override the default resources but there are some tricky areas for stuff other than images where stuff should be combined together for when new things are added to moi.css for example that the theme doens't implement.
It's something that I want to work on in the future but it probably won't happen in the V4 time frame though.
