>> you can do now is the option under Options > General > Side pane position: "Inside". <<
Yes, this is the option I currently use and generally it works well for me. I just feel if I could simply switch between palettes, scrolling the side bar would usually be unnecessary (excepting projects with many named objects etc).
.>> you can.....set up a keyboard shortcut that will toggle the side pane visibility. <<
Thank you, this a great tip. I will do this immediately. I might see if I can link it to a custom icon
Thanks again
