| Hi 3DFanatic,
 > One thing i noticed using straight lines to cut an object that has depth it will cut
 > without issue. Basically all sides stay intact but once you fillet the point section then
 > when cutting the edges then the edge is gone maybe to complicated to hold the edge
 > any thought thanks
 Can you please post the 3DM model file with the object in it that you're having this problem with? It's hard to figure out what might be going on by just a text description like that, I'd need to be able to take a look at your object.
