| Hi Michael,
 >>it would be pretty awkward for a user to set up multiple point arrays like that and
 deal with selecting them.....seems like a lot of specialized set up would be required.<<
 I have only used an early WIP mac version of rhino which did not have this functionality.
 Is the the setup for paneling tools in Rhino awkward and a lot of specialized set up required?
 The initial point array is generated from a surface, and the second may be simply an offset of the first.
 Though by manipulating the second point array, the resulting pattern may have a varied topology
 across the surface as shown the rhino images in earlier post.
 .>>But a similar thing that might be easier to build into Flow though
 would be an option in Flow for a number of tiles in U and V to generate,
 although that would probably generate curved walls on the output same
 as if you did a Flow on the curved surface right now.<<
 Node editor already handles the tiling of flowed items, it is the deformation
 of the tessellation as a whole rather than individually that is the problem.
 Is this what you me by a "segmented" option?
 You mentioned "cage edit" in your first reply.
 Is that something planned for Moi3d?
 I think you are right: cage editing functionality together with
 node editor for  coupling of control vertices of the cage to
 the points of 2 point arrays would solve this problem.
 No doubt there is a better way, and if anyone can find it, it's you.
 -James
