This scrip made Max Smirnov, it replace sharp corners to regular points.
It has to be improved a bit, Max has no time now so I asking you.
1. it keep curves with sharp points and you have to delete them by hands, but it wiil be good to delete them automaticly.
2. Now before script starts it allows you to deselect sharp points and they will be deleated insted of replaced to normal points. So if I have a lot of curves to modify I have to skip this step one by one, it take a lot of time and in the end if I press enter after I skip last curve script runs again, and it becom big pain...
So it will be possible to select all curves run script and all sharp points will be replaced with regular and initial curves will be deleated.
3. This script works great after you aplly fillet to sharp points if you want to keep shape. It keeps very good shapes of curves. So could you pleas some how incorporate this script with fillet, so first run fillet after that script.
Also fillet now works only on 1 curve for this script will be great to have fillet for multiple curves at once it will be great not only for this script.
Thank you.
http://www.datafilehost.com/d/06b9c073
