A small continuity problem there
6888.1
Hi everyone,
I'm modeling an iPhone 6 for a client and I've got a small continuity problem I think
See I'm trying to do a curve then a sweep to make the backside of the phone, the back is perfectly flat which is correct (yes I got an iPhone 6 to verify, outer shell only, non functional)
The sweep curve has G2 curvature (rounded corners)
Here in the attached 3DM file you'll find my result so far, is there a way to improve it? The profile curve has been hand drawn from a side scan so it's visually accurate but I don't care about being accurate to the micron
Any help or advice on how to build such a shape would be greatly appreciated
Kuto.ch / freelance graphic designer and 3D generalist
Size: 379.4 KB, Downloaded: 30 times, Dimensions: 1135x638px
