Lofting Hull and Fuselage
6887.4 In reply to 6887.3
Elrico, it is not necessary to copy profiles you just have to try to keep the same amount of points in profiles for better result, copyng is just the simple way to dublicate profiles. Also in that tutorial I used very small profile at the end now you can use point instead.
EDITED: 1 Sep 2014 by ANDREI SAMARDAC
