Lofting Hull and Fuselage
6887.32 In reply to 6887.31
Elrick,
The truck was scanned with the Focus3D from 6 locations (6 scans). Actually, we did not need most of what was scanned, just the area around the grille and bumper. Each scan typically takes 5 - 10 mins but this can vary depending on accuracy (sampling), point spacing, and color. If you don't need colored points (the scanner can take a set of photos to color the points) 5 mins or less per scan would be typical, particularly if you limit the scanning angle. The scanner is placed on a tripod and it rotates automatically around the vertical axis.
SolidWorks is good for many things, but constructing freeform or organic surfaces can be difficult and time consuming. Additionally, it does not have the tools to make the quality surfaces that are often needed for cosmetic work ie. Cars.
SolidWorks has various levels and add on packages, and it can get quite expensive. I just have the Standard version.
Size: 410.8 KB, Downloaded: 27 times, Dimensions: 1280x1022px
Size: 512.5 KB, Downloaded: 33 times, Dimensions: 1315x857px
Size: 341.1 KB, Downloaded: 35 times, Dimensions: 1033x806px
Size: 492.3 KB, Downloaded: 33 times, Dimensions: 1034x794px
