How to Network this?
6879.6 In reply to 6879.1
Hi BlackBird, yes as others mentioned above it's probably a better idea to make a full surface to start with and then trim away the wheel well area after the initial big surface is created, rather than trying to incorporate that directly into the surface construction itself.
When some of your network section curves have sharp corners in them like you've got for the wheel well area, usually those sharp corners will have their sharpness come through as creases across the network in those areas. It's better for sharply cut outlines to be formed by trimming.
The other thing that will be problematic for your Network layout there is having 2 sections touching each other at a single point here:
The curve layout must form a completely regular grid - if endpoints of sections are touching each other then all the sections from that direction should come to that touching point (making something similar to the north pole or south pole on a globe, with lines of latitude and longitude), not just some of them.
