Need some help with fillet
6868.4
Hi OSTexo, Hi Michael,
I run into these type of thing a lot when I'm using fillet.
Most times I try until something works or try something else.
I've been doodling for most of the time now.
Trying to learn the features and tools of MOI .
So now that I'm really starting to make actual models I want know if im doing things wrong or how to fix things.
So thanks for the detailed description on how to salvage the fillet OSTexo.
I will give certainly give it a try.
The problem with the bottom part is clear to me Michael.
Thank you to for the detailed explaination.
The problem with the top part is what I encounter the most when using fillet.
But if I understand correctly there nothing I can do different to prevent this from happening?
There is nothing wrong with the way I modeled the solid or something?
If it does happen, the only thing I can do is to try OSTexo's method of trying to salvage the fillet parts?
If it's a bug that can be fixt in the future.
Maybe it's helpful for you, If I send you a file each time I encounter such a problem?
Regards,
Glenn
