Smooth extension needed
6863.1
Hello,
I need to smoothly extend a section by about 20mm-25mm. At the end the extension should be 4mm thick actually about 10mm should be 4mm thick. The extension (red) should smoothly blend into the existing part and extend seamlessly the top surface of the part. The extension should only apply to a certain length of the part.
I have bee playing with cuts, blends, sweeps but didn't get a nice result.
The attached model shows the idea of the part.
How can I partially extend the "edge" of the part with a seamless extension the top surface?
S.
