Made some progress.
There are still some problems.
The script is confusing the two curves. It prefers to use the bottom one. :-)
Cannot extract the y value of the points.
/code
projectfactory.update();
var ktpointobj = projectfactory.getCreatedObjects();
var ktpoint = ktpointobj.item(0);
// var ktpointlist = projectfactory.calculate();
// var ktpoint = ktpointlist.item(0);
// moi.geometryDatabase.addObject( ktpoint );
//alert ("ktpoint.x = " + ktpoint.x + "\nktpoint.y = " + ktpoint.y + "\nktpoint.z = " + ktpoint.z );
var kORtValue = ktpoint.y;
return kORtValue;
/code
Still getting asserts in two patterns associated with for loops. 9 = 1+4+4, 4, 4, 4
First loop has no assert, so the asserts are probably caused by failure to extract y values. (Guess)
