Script for Isocurves to automate it.
6841.8 In reply to 6841.7
> But U+V must be made in 2 pass ! (we have the Menu U+V , U, V visible)
> Does this normal ?
It depends on the surface you're using it on - but yes often the edge that you select as the generator will be running in the U or V direction and in that case only the opposite one will work with that edge. You would then need to select an edge in the other direction to make the other set.
