Hi Max,
i found a bug in nodeeditor...
if you have a slider or knob you can change values with the mousewheel - but if you use a MagicMouse2 or a trackpad it causes NaN if you scroll sideways...
if i go to interface.js and delete all the:
WidgetKnob.prototype.onMouseWheel = function(e)
	var v = this.internal.position;
	var delta = e.wheelDeltaY/Math.abs(e.wheelDeltaY)/100;
	var time = LiteGraph.getTime();
	if ( time - this.local.wheelTime < 50 ) { delta *=5 }
	else if ( time - this.local.wheelTime < 100 ) { delta *=2; }
	this.local.wheelTime = time;
	v += delta;
	if (v> 1.0) { v = 1.0 } else if (v < 0.0) { v = 0.0 }
	this.internal.position = v;
	this.properties.value = this.properties.min + (this.properties.max - this.properties.min) * this.internal.position;
	this.properties.value = this.properties.value.toFixed(this.properties.digits);
	this.updateThisNodeGraph();
	this.graph.setisChangedFlag(this.id);
No more Mousewheel ;-(
but no more NaNs :-)
THX for nodeeditor!!
  Ralf:)
looking for moments of inspiration... |
