How to transform a multi surface part into a machinable solid (STL)?
6833.2
Hello simba,
Your model is not symmetrical, that is why you have a gap between the wing and the fuselage. You might want to work backward a bit to see where your mirroring went wrong. Otherwise you could Trim your model in half, Mirror the half and Join the result into a solid.
