fuselage - wing joints using blend?
6827.5 In reply to 6827.3
> Seems your curves are not on the surface!
Yeah it seems to be a bit off. But it's close enough that it can be used to trim the surface ok. Once you have done the trim then discard the curve and use the new trim edge instead for doing the blend.
